Why won't the panoramic image open? Clicking it doesn't respond, and it also doesn't switch to the camera when I put it in reverse gear. What's the reason?
I've upgraded my 2009 Scirocco with the 187b head unit, but the reverse camera doesn't switch the screen when reversing, although the radar works fine. Interestingly, the reverse camera works normally when the car is off, but not when the engine is running. I've already replaced the head unit and the reverse camera, but the issue persists. Any experts out there who can help?
Has anyone encountered a situation where the 2017 Smart car doesn't respond when put in reverse gear, and the engine warning light is on?
The trunk won't open, what's going on? Is there a switch inside? Thanks.
4Why won't the trunk of my 2008 S40 open? What could be the reason?
5Why won't the panoramic image open? Clicking it doesn't respond, and it also doesn't switch to the camera when I put it in reverse gear. What's the reason?
6Have you encountered a situation where the reverse camera image is missing the borders and only the image is displayed? How can it be restored to normal?
7The side electric sliding door of the Multivan can open, but it doesn't respond when closing. What could be the reason?
8Why won't the sunroof close, and why isn't the switch responding?
9What could be the reason that when I press the key, the car doesn't respond and the doors won't open?
10I feel like the reversing camera image is not clear. Can I replace the camera individually?
