علي عبد الحكيم
2024-09-21 11:55
Will the car's catalytic converter get clogged?
محمد بكر
محمد بكر2024-09-21 18:52
Even the best pot will burn your food if you don't know how to cook.
How many catalytic converters does the Acura MDX have? Does anyone know?
My catalytic converter is poisoned. Can any experts recommend a cost-effective vendor to replace it?
Does the 2019 SAIC Maxus T60 diesel have a catalytic converter?
Fuel not getting through, no power, engine warning light is on. What's the situation? Is it the fuel injector or the catalytic converter?
The mechanic replaced the catalytic converter for me, but now the car lacks power when climbing and accelerating. Do I have to buy an original catalytic converter? The original one is quite expensive, over 5000.
Have any fellow car enthusiasts encountered a situation where the catalytic converter has minor cracks, causing occasional exhaust emissions to go uncatalyzed and triggering the emission warning light? The mechanic mentioned this. I regularly use Carpol's catalytic converter cleaner, Liquid Gold, etc., so there shouldn't be a carbon buildup issue.
Where is the number for the catalytic converter?
Hello fellow car enthusiasts! I bought my ZS at the end of 2019, and it has driven over 120,000 kilometers so far. Recently, it started showing a fault code indicating that the catalytic converter efficiency is below threshold. Has anyone else replaced their catalytic converter? What was your experience? Thanks!
Does the 2024 Highlander's particulate filter still get clogged? Fellow car enthusiasts, is your particulate filter still getting clogged? I've heard that the materials used now are better, so the chances of clogging are lower. I'm considering just replacing it with an empty shell to avoid future headaches.
