علي داود
2024-12-01 18:13
Is it really noisy when driving? Even with the windows tightly closed, there's still a lot of noise inside.
سلمان مطلب
سلمان مطلب2024-12-05 09:45
I'm feeling okay.
نايف خليف
نايف خليف2024-12-03 18:27
The original tires have a lot of road noise. When driving at high speed, you have to turn up the music loud to cover it. The first batch of the 2020 model didn't come with engine bay insulation, so you have to add it yourself. I'm not sure about the later batches.
عبدالرحمن حسن
عبدالرحمن حسن2024-12-02 15:36
Who said that? That's exaggerated.
Is the car noisy when driving at high speeds?
Is it noisy for people sitting in the car while driving on the highway? Specifically, when the boss is driving at high speed, is the exhaust sound loud inside the car during normal driving? Looking forward to your insights! 😊
Is the noise inside the car loud when driving on the highway?
Can the rubber bushings be replaced? The car makes a lot of noise when driving over bumpy roads.
Does the 2020 ASX with a 2.0-liter engine have a window-closing function when locking the car?
When driving at high speeds, there's a ticking noise from the driver's side window that sounds like raindrops hitting the glass. At first, I thought it was raining, but it wasn't. The right window is fine. The noise disappears when I lower the window. Could it be caused by the window seal? Has anyone else experienced this? How did you solve it?
Does the 2013 Roewe have automatic window closing when locking the car, or can the windows only be closed by holding the lock button?
When the window glass in the Outlander's cabin is lowered and the door is closed with a bang, what's going on?
Do you have issues with window noise? When the car is parked outdoors, during rainy or very hot days, after starting, there's a creaking sound from the rooftop or windows, which disappears after driving for a while. I should mention that if it's parked in an underground garage, there's no noise. Even after reopening and closing the sunroof, the problem persists. When the noise occurs, it gets louder if the road is uneven. The model is a six-seater.
When driving on uneven roads, there's a jingling noise coming from the rear of the car. But when the windows are closed, the sound can't be heard. What could be the issue? I suspect it might be the silver trim at the rear.
