عمر نوري
2024-11-28 21:27
I bought a VS7 in 2024, and it has run 5800 kilometers so far. When the car goes over 50 km/h, there's a continuous rattling noise coming from above the dashboard. The faster I go, the louder it gets. I don't know what the problem is. Any ideas?
عمر مك
عمر مك2024-11-29 12:01
I used to have a vibration issue, where the steering wheel would vibrate as soon as I hit the gas. After turning off the engine and letting it sit for an hour before restarting, it should be fine.
خالد وهاب
خالد وهاب2024-11-29 11:24
The central control air conditioning panel interface is not tight. I'm experiencing the same issue.
Is there anyone else experiencing a rattling noise from the left corner of the dashboard in a 2015 V40? I haven't been able to find the cause.
I have a 2016 S5 manual, and recently the engine noise has become quite loud, with a rattling sound. The mechanic said the tensioner bearing is broken. When I'm driving and press the accelerator, there's a ticking sound that gets faster the more I press it, but it stops when I release the pedal. Does anyone know what might be happening...?
Hey guys, how do you reset the trip meter above the total mileage on the dashboard? I have a 2011 base model, manual transmission, 1.4L hatchback.
2017 model 1.4T, now the temperature is around 3°C. When I start the car, the RPM is at 1200, and when I start driving with a cold engine, the RPM goes above 3000 before it shifts gears, and it feels shaky. Do you guys experience this too?
The "circle A" symbol for the start-stop system on the 2021 GV80's dashboard is flashing continuously, and the RPM won't go above 2500. Pressing the start-stop switch doesn't make any difference. Can anyone help explain what's going on?
I just bought a 2018 model 1.0 Passion Edition. Could anyone advise on the best spot to install the parking sensors? Most of the aftermarket sensors need to be at least 50 cm above the ground. The original ones are on the black plastic part and are quite low. So, I'm seeking advice from everyone. Thanks!
For a 2013 Suzuki Swift, if you're experiencing a buzzing noise at speeds of 40 km/h and above, and the noise gets louder as you go faster, what can you do to reduce the sound? Any advice from experts would be greatly appreciated. Thank you!
Hi everyone, can someone help me out? Today, I suddenly noticed a noticeable "da-da-da" sound from the engine when it goes above 2000 RPM. What could be the issue?
Who knows how to turn off adaptive high beams? I set it up and found that when I manually turn on the low beams, the dashboard indicator light goes off, and I still can't figure it out.
Anyone else experiencing occasional rattling noises from the 24 model's dashboard? It sometimes goes "dang dang dang," but when I take it to the dealership, the noise disappears and they can't find the issue.
