Do you feel that the chassis of your Xiaoqi feels a bit loose when going over rough and hard surfaces, like uphill and downhill? Mine feels a bit loose, and it's only 20,000 kilometers in. I usually don't drive on rough roads, just once on a mountain road with stone slabs and once over a speed bump in the parking lot, and it didn't feel good.
When driving over slightly rough roads, there's a clanking noise from under the front wheels, like metal hitting metal. Has anyone else experienced this?
Hey everyone, my 2006 car feels like it's jumping when turning over speed bumps or similar surfaces. Any idea what might be causing this? Thanks!
Has anyone experienced the same issue with the 2016 Jeep Renegade? When driving at speeds of 60-80 km/h over manhole covers or bumpy roads, the rear end feels loose (swaying side to side). The car hasn't been in any accidents, the rubber bushings seem fine, and the wheel alignment data is normal.
4Hello fellow car enthusiasts, has anyone installed coilover suspension on their car? Can it improve the chassis feel? My car is a 2017 4WD Elite with over 90,000 kilometers. When I go over speed bumps or drive on rough roads, the chassis makes a clunking noise. Will installing coilover suspension help?
5When driving at low speeds over rough roads or speed bumps, and then accelerating, the RPM between 1100 to 1500 feels like it's cutting out. Once the throttle picks up, everything returns to normal.
6When the Sportage makes a thumping noise over uneven road surfaces, what's the issue?
7I've driven over 50,000 kilometers with the 2.4 AWD version, and I always feel like the feedback from the road is too noticeable when driving on rough roads! It's not comfortable at all. Is it designed this way, or could there be other reasons? Can any fellow car enthusiasts shed some light on this? [Sad][Sad][Sad]
8Does anyone feel the car shakes a bit noticeably at speeds over 120? Could it be because of the hard seats? I have a 2.0 Macan. Any brothers with the same feeling? Let's chat.
9Do you feel that the chassis of your Xiaoqi feels a bit loose when going over rough and hard surfaces, like uphill and downhill? Mine feels a bit loose, and it's only 20,000 kilometers in. I usually don't drive on rough roads, just once on a mountain road with stone slabs and once over a speed bump in the parking lot, and it didn't feel good.
10I got my car in August 2024, and when the left wheel goes over rough roads, there's a metallic clanking noise. What could be the issue?
