Looking to purchase two rear shock absorbers, removed from a modified Vito.
Does anyone know where to buy rear shock absorbers?
Is this car exempt from the purchase tax? [shocked]
Is there any fellow Haval owner experiencing a clunking noise from the front right shock absorber when driving on rough roads?
4Do any of you with the old 2012 model of Changan Yuexiang have issues with rear wheel shock absorber top corrosion and rust, leading to the shock absorber falling off? If you do, please type 1, thank you.
5Looking to purchase two rear shock absorbers, removed from a modified Vito.
6Looking to modify the shock absorber, does anyone have the wiring layout diagram for this car?
7Has anyone here ever changed the front shock absorber top mount on an Ertiga by themselves? Is it possible to replace the front shock absorber top mount without removing the shock absorber itself? How do you get the top mount off? Any guidance would be appreciated. [Embarrassed face]…
8Is it troublesome to replace the shock absorbers on a Mazda 6? I noticed during maintenance a few days ago that both the front and rear shock absorbers are starting to leak oil.
92018 Peugeot 308 1.6L has a clunking noise when turning the steering wheel. Replaced two shock absorbers and the left strut mount bearing, the noise reduced but it's still there.
10Why is my car's rear shock absorber leaking oil? Is this covered under warranty?
