Hi everyone, since the Vito Elite 8-seater has a 2-3-3 layout, does the second row have sliding rails? How do you get into the third row? I've been wanting to buy the 8-seater Elite but I'm really worried about the access problem. [Facepalm][Facepalm][Facepalm]
Comments( 6 )
Can the third-row seats in a 7-seater be removed?
4Congratulations on getting your driver's license and your 2012 manual March! When it comes to maintaining a second-hand car, there are a few key things you should check and possibly replace: 1. **Engine Oil**: It's essential to change the engine oil and oil filter regularly to keep the engine running smoothly. 2. **Brake Fluid**: Check the brake fluid level and consider flushing and replacing it if it's old or contaminated. 3. **Coolant**: Ensure the coolant is at the proper level and in good condition. Replace it if necessary. 4. **Transmission Fluid**: Since your March is manual, check the transmission fluid and change it if it's dirty or hasn't been replaced in a while. 5. **Power Steering Fluid**: If your car has power steering, check the fluid level and condition. 6. **Air Filter**: Inspect the air filter and replace it if it's dirty to keep the engine breathing well. 7. **Spark Plugs**: Check the condition of the spark plugs and replace them if they're worn out. 8. **Tires**: Check tire pressure and tread depth. Rotate the tires if needed and ensure they are in good condition. 9. **Battery**: Check the battery condition and clean any corrosion on the terminals. Regular maintenance is key to keeping your car in good shape. Make sure to follow the maintenance schedule recommended in your vehicle's owner's manual.
5For the 2023 Model X, there are several accessories you can consider to enhance practicality beyond the basic seat covers and floor mats, especially for your 5-seater version. Here are some suggestions: 1. **Trunk Organizer**: Helps keep your trunk tidy and maximizes space usage. 2. **Sunshade**: Protects the interior from heat and UV rays, keeping the cabin cool. 3. **Screen Protector**: Prevents scratches and reduces glare on the touchscreen. 4. **Wireless Phone Charger**: Convenient for charging your phone without cables. 5. **All-Weather Floor Liners**: Offer better protection against dirt and spills. 6. **Roof Rack**: Adds extra storage capacity for trips and outdoor activities. 7. **Console Wraps**: Personalizes the interior and protects from scratches. 8. **Portable Vacuum Cleaner**: Keeps the interior clean, especially useful for families or pets. These accessories can improve the functionality and comfort of your Model X.
6Can the second and third rows of the seven-seater version be folded flat?
7I want to get a new car for my wife. She's currently driving an IS. After looking at a lot of cars, only the G70 shooting brake seems relatively pleasing. Here are my main concerns: 1. A friend mentioned that there's not much difference between the two cars, and the IS might be slightly better, so it may not be significant. 2. Recently, many car companies are offering discounts and promotions, but the manufacturer currently shows no sign of doing so. 3. Both cars require ordering and production scheduling, which means a long waiting time, making it awkward. 4. Since it's all about ordering and production scheduling, the options and configurations are not flexible enough. 5. I'm worried about their sales and the potential of dealership closures. Have any other car owners faced similar awkward issues? [Facepalm]
8Does this car have good off-road capabilities, suitable for road trips? The back seat seems really spacious, good for sleeping, right? I'm not too worried about fuel consumption since it's American, as long as it's not too bad. I'm just concerned that besides being big, it won't be like a car costing around a hundred thousand [facepalm][facepalm] How's the driving experience and all that?
9Do you think there will be discounts on the 2024 model after August, since many people are waiting for the 2025 model? I'm also worried about missing out. I don't have high demands for smart driving, and I feel like the 7-seater in the back doesn't have small tables. Plus, there are no discounts for non-ZEEKR users. Sigh!
10Why doesn't the third row of the Zeekr 009 have a heating function, even in the 6-seater executive version? In my opinion, since it's an executive version, all six seats should have heating, ventilation, and massage modes. The more luxurious the first two rows are, the more awkward the third row feels.
