What should I pay attention to when maintaining a Vitara 1.4T automatic? Which brand of engine oil and filter is better? How often should the air conditioning filter be replaced? At how many kilometers should the original spark plugs and brake fluid be replaced, and what brand of battery is recommended to be replaced with?
What spark plug model should be used for a 2014 Suzuki Grand Vitara with a 2.4 engine?
What should I pay attention to if I'm considering buying a 2014 Toyota 86 with an automatic transmission?
4I bought a used 2015 1.6T V40 with 50,000 km on it. What should I pay attention to, and what areas should I maintain myself? I hope fellow car enthusiasts can give some advice.
5What should I pay attention to when buying a used car from around 2017 that has been modified?
6What should I pay attention to when maintaining a Vitara 1.4T automatic? Which brand of engine oil and filter is better? How often should the air conditioning filter be replaced? At how many kilometers should the original spark plugs and brake fluid be replaced, and what brand of battery is recommended to be replaced with?
7Is the gasoline filter of the Vitara 1.4T external or internal?
8Car enthusiasts, which brand of spark plugs do you recommend? Is everyone using Mitsubishi NGK single iridium spark plugs?
9How often should the spark plugs in the 2019 GS5 be replaced? It's approaching 70,000 kilometers and hasn't been changed yet.
10Is there any oil seeping into the cylinder from the spark plug? Should this be addressed?
