In the past month or two, my Vitara has experienced difficulty starting on two occasions. It takes several attempts to get the engine running. What could be the reason?
What could be causing starting difficulties, where sometimes it takes two or three attempts to start?
Has anyone experienced starting issues with their car? This problem has been going on for over a year. I've replaced the battery, cleaned the fuel lines, changed the spark plugs, and replaced the fuel pump, but still can't find the issue. The dealership is also at a loss. Every time I try to start the car, it takes three attempts to get it running. It feels like the fuel isn't reaching the engine when starting. I'm now afraid to drive, because if the engine stalls, it'll take three attempts to start it again. 😢😢😢 Does anyone know the reason?
Hey fellow car enthusiasts, my Sportage suddenly started beeping and wouldn't start, no idea what I touched. It seemed like closing the hood fixed it. Has anyone else experienced this? It's happened to me two or three times in the past couple of months. Does anyone know how to solve this?
4Today, after starting the car, the engine vibrates quite severely, but after a while, it gets better. Does anyone know what the reason might be?
5In the past month or two, my Vitara has experienced difficulty starting on two occasions. It takes several attempts to get the engine running. What could be the reason?
6Why does it take two or three attempts to start the car?
7I have a 2015 Honda City. Sometimes it takes two or three attempts to start. What's the issue, experts?
8What could be the reason that the air conditioning in my 2011 Phaeton blows cold air before hitting the highway, but gets warmer the longer it runs?
9Has anyone else experienced the issue where the car's data is turned off by default these past two days, and you have to manually turn on the network? How did you solve it?
10How long does it usually take to get the car after placing an order? It's been a month now, and it's still in production... 2024 model, 2.0 two-wheel drive tech, priced at 19.8.
