I've got a 2016 manual Vitara, and I've noticed marks on all four door screws. It's a used car, so I'm worried the doors might have been repaired. Do other owners have the same issue?
Does anyone know how to fix the issue of no warm air in a 2009 Suzuki Grand Vitara five-door version? I've already cleaned the heater core.
The speed of the window operation in my 2016 GT has noticeably slowed down. Could it be due to some obstruction inside? If I take it for repairs, is it necessary to remove the door panel to inspect it?
Hey car enthusiasts, I've got a 2012 Mazda 5 that's had its gearbox repaired. How long can it last? Just bought it second-hand.
4I just got a 206, and I've noticed that the body is lowered. Is it coilovers or lowering springs? I noticed the rear chassis is different from regular cars. Any advice?
5For the 2016 Vitara automatic two-wheel drive Elite version, it's generally recommended to use 5W-30 engine oil. If you just changed the oil and noticed a one-liter increase in fuel consumption, it might be worth checking if the oil type and specifications are correct for your engine.
6How to use the V40's automatic parking feature? I've never used it before. Can it park in any type of parking space, or does it have to be a standard marked space? I'm a bit confused.
7I've got a 2016 manual Vitara, and I've noticed marks on all four door screws. It's a used car, so I'm worried the doors might have been repaired. Do other owners have the same issue?
8My Kodiaq's rear inner tires are wearing unevenly and noticeably. The repair shop says the lower arm needs to be replaced because it's not an adjustable one, so four-wheel alignment can't be done. Does anyone know if this is correct?
9My Kodiaq's rear tire is wearing unevenly, with noticeable wear on the inner side. The repair shop says I need to replace the lower arm because it can't be adjusted, and then do a four-wheel alignment. Is this the case?
10Has the leather on your car's door handles peeled off? All four of my door handles have this issue.
