For the 2016 Vitara automatic two-wheel drive Elite version, it's generally recommended to use 5W-30 engine oil. If you just changed the oil and noticed a one-liter increase in fuel consumption, it might be worth checking if the oil type and specifications are correct for your engine.
Yesterday, I went for maintenance, and they usually use 5W-30 oil. But this time, the technician used 5W-40 oil. I'm not sure if this will have any impact.
For the 2016 Roewe 1.5 automatic, do you use mineral oil or 5W-20 or 5W-30?
For a 2017 Honda City with 90,000 kilometers, what type of engine oil should be used? Should it be 20 or 30?
4What does it mean when the idle is a bit rough? Do you all use 5W-30 oil?
5What type of oil is suitable for a 1.4 naturally aspirated manual engine? Is 5W-30 okay?
6For the 2016 Vitara automatic two-wheel drive Elite version, it's generally recommended to use 5W-30 engine oil. If you just changed the oil and noticed a one-liter increase in fuel consumption, it might be worth checking if the oil type and specifications are correct for your engine.
7Is the engine oil for the 2013 Alto 5W-30 or 0W-20?
8I've been driving a 2009 Kia Sportage manual GLS with 120,000 km on it. I've always used 5W-30 engine oil, but recently it seems to be burning oil a bit. Should I switch to 5W-40 oil for maintenance? Has anyone experienced this before and can share some insights?
9Is the Mobil 5W-40 oil I used today not as good as 5W-30?
10What type of engine oil is generally used for the 2019 model?
