عبدالله حريري
2020-04-17 15:03
Does your Vitara make any noise when going over speed bumps? I feel like there's some noise coming from the brakes or suspension area in my car.
محمد حريري
محمد حريري2024-03-16 20:57
Check the strut mount and shock absorber.
خالد مكرم
خالد مكرم2020-04-18 19:18
The sound of a suspension spring.
نايف جابر
نايف جابر2020-04-17 15:20
You might want to check your suspension. The noise could likely be due to loose springs or the suspension system lacking lubrication.
The 2014 Model S P85 makes a rattling noise from the right side of the chassis when going over small bumps, manhole covers, and speed bumps. I've already replaced the control arms, but the noise is still there. Does anyone else have the same issue? How can it be resolved?
Help needed, the suspension of my V40 makes squeaky noises when getting in and out or going over speed bumps. I called for advice and they said it might be due to aging bushings. Has anyone else encountered this issue?
It's uncomfortable going over speed bumps, it's very bumpy. What's up with the suspension?
Hello fellow car enthusiasts, has anyone installed coilover suspension on their car? Can it improve the chassis feel? My car is a 2017 4WD Elite with over 90,000 kilometers. When I go over speed bumps or drive on rough roads, the chassis makes a clunking noise. Will installing coilover suspension help?
When driving a Vitara 4WD at high speed and braking, do you experience feedback or a pulsation in the brake pedal?
My car is a 2019 model, and I've driven many cars, but none of them make the hissing sound over speed bumps like mine does. I haven't driven other Kodiaqs. Is it an issue with my car, or do all Kodiaqs have this kind of suspension noise?
Driving over speed bumps at 60 km/h can indeed have an impact on your car. It might cause stress to the suspension system, tires, and potentially the alignment. It's always best to slow down for speed bumps to avoid any potential damage.
I bought a second-hand 2013 2.0 Peugeot 3008, and I feel like the rear suspension is really stiff. What can I do about it? Going over speed bumps makes people bounce up. Any advice from experts?
Suzuki Suzuki Vitara
Suzuki VitaraAED 64,900 ~ 83,900Gasoline & Petrol
