What could be the reason for the engine shaking when the Viano is parked in D gear?
What could be causing the severe engine vibration in a Viano?
What could be the reasons for the Navara's parking air conditioning not cooling effectively?
When the old model Vito is at a red light and you shift from N to D, causing the car to lurch forward, what could be the reason?
4If the Haima S5 manual transmission shakes when starting without giving gas and runs at idle speed, what could be the reason?
5What could be the reason for not being able to shift gears when the car is cold?
6Car enthusiasts: Sometimes when driving a small car, the D gear won't shift up. The RPM suddenly goes up, but the gear doesn't match. What could be the reason?
7What could be the reasons for not being able to shift gears?
8What could be the reasons for not being able to shift gears?
9What could cause a loud banging sound when I shift gears after the car has been parked overnight?
10What could be the issue if the car shakes after being parked for a long time?
