أحمد شاكر
2020-12-16 09:20
The Viano has a power leakage issue. In less than a week, the battery is completely drained, even the remote control for the doors doesn't work. Still can't figure out the cause.
عبدالله بكران
عبدالله بكران2020-12-16 10:30
You might want to try another 4S dealership. It's easier to check for parasitic current with a current clamp. Service centers that only have multimeters find it particularly hard to detect. If it's a financed car, consider that the GPS might be draining the battery.
The air conditioning isn't cooling. I checked the pipes and found no leaks. However, after adding refrigerant, it was gone in less than two months. For an 11-year-old imported Mazda CX-7, what usually causes this issue?
I've been driving the T8PRO diesel 4WD for less than half a year, and it's been having engine emission issues all the time! I have to go to the service center at least once a week for diagnostics. I'm wondering if this problem can't be permanently fixed...
It could be due to several reasons such as engine misfire, idle air control valve issues, or even problems with the transmission mounts. It's best to have a mechanic check it out to diagnose the exact cause.
The Jietu 90 has too many issues. At less than 20,000 kilometers, the one-touch start fails to work, and the 360 camera malfunctions, sometimes even resulting in a black screen.
Hey buddies, does anyone have a rattling noise from the passenger side dashboard? My car is from 2021 and has less than 60,000 km. It happens when I turn on the power, while driving, and sometimes even when it's off. The noise also appears when I turn on the AC and occasionally when using the wipers.
If the remote control function of your Peugeot 307's key is not working, even though the key itself is in good condition, what could be the issue?
What could be causing the wipers and headlights of my 2014 Peugeot 308 to activate automatically after locking the car? It's inconsistent and seems random, regardless of rainy or sunny weather. I recently took a trip, left the car under the sun, and when I returned, the wipers were upright, and the battery was completely drained. I just replaced the battery. It's really frustrating.
Does your 1.6 naturally aspirated engine consume oil too? Mine has only run about 90,000 kilometers, and after the last maintenance, I drove less than 2,000 kilometers before the oil light came on. When I checked the oil dipstick, it couldn't even reach the oil level.
The steering wheel is crooked 🤦‍♂️. Even after doing a wheel alignment, it can't be fixed. The mechanic said it's caused by a deformed lower control arm?
