عبدالرحمن موسى
2020-09-10 11:49
The rear wheels of my Viano are experiencing severe tire wear, and there's a misalignment of 0.9 that can't be corrected with standard alignment. Seeking advice from experts for a solution.
عبدالرحمن وسيم
عبدالرحمن وسيم2020-09-30 08:04
Air suspension issues are usually caused by control arm deformation. The repair and replacement costs can be quite high. It's recommended to regularly inspect the tires and replace them periodically.
نايف طائي
نايف طائي2020-09-11 22:55
If balancing and alignment don't work, it might be an issue with the suspension system's mechanical parts. It's a good idea to have an experienced mechanic check it further.
نايف برهان
نايف برهان2020-09-10 12:41
It seems like there's an issue with your wheel alignment. You might want to get the wheel alignment done again. If it can't be adjusted, there might be a problem with the suspension, which could have deformed over time.
I've been using the 2017 MDX for over a year, and the front tires are wearing out unevenly. After rotating the rear tires to the front and doing an alignment, the newly replaced tires are again showing severe uneven wear. Have any other car owners experienced this situation? Looking for advice.
The gear is constantly showing in N position. There's no response when shifting to A or reverse gear. Seeking advice from experts. What might be the issue?
Can a wheel alignment be done if the rear tires of a 2015 Sportage are wearing unevenly?
I'm looking for advice on my 2016 Volkswagen Multivan 4WD that's experiencing severe tire wear. I've done a wheel alignment, but it hasn't resolved the issue. Any insights would be appreciated.
Is it necessary to do wheel alignment after picking up the car? I did some research and found that issues with the camber angle can lead to inner tire wear. Not sure if the new model has this problem?
Why can't CarPlay connect? I've tried several different cables but still can't connect. Any experts here to help?
My Kodiaq's rear inner tires are wearing unevenly and noticeably. The repair shop says the lower arm needs to be replaced because it's not an adjustable one, so four-wheel alignment can't be done. Does anyone know if this is correct?
My Kodiaq's rear tire is wearing unevenly, with noticeable wear on the inner side. The repair shop says I need to replace the lower arm because it can't be adjusted, and then do a four-wheel alignment. Is this the case?
Are there any fellow drivers experiencing severe rear tire wear? After 30,000 kilometers, the rear tire treads are down to the warning line...
Has anyone done a wheel alignment? My City has uneven wear on the left rear tire and slightly pulls to one side. I've heard that the City’s rear wheels are non-adjustable and you can only add shims during alignment. Is this safe? Also, is it necessary to do a wheel alignment since the tires are quite cheap? 🤦‍♂️
