سعود أمينة
2020-12-10 19:24
How to fix the steering wheel noise in a Viano?
محمد عبد الغفار2020-12-10 19:33
It could be an issue with the steering gear. Check if there's a problem with your power steering. It might also be related to the tie rod, including wear on the ball joint.
Is there a strange noise when you turn the steering wheel?
Has anyone replaced the steering gear on a Viano?
How to unlock the steering wheel?
4How to fix the heavy steering of a Pajero?
5How to fix the steering wheel pulling to the right?
6When turning the steering wheel, there's a strong "kang kang" noise. Does anyone know how to fix this? Can't seem to find the problem.
7The steering wheel is not straight, but the car doesn't drift. How can I fix it? Thanks.
8Hey guys, is your steering wheel heavy? Mine feels a bit heavy. How can I fix this?
9What causes the steering wheel to make a noise when turning the shaft?
10How to fix the sunroof noise issue?
