أحمد عبدله
2021-02-13 19:45
Does the Viano have a timing belt?
سلمان جمال2021-02-13 22:07
This car has been out of production for a long time. The older model uses a timing belt, which is quieter. However, you need to check and replace it after about 70,000 to 80,000 kilometers.
How many batteries does the Viano have?
Do I need to change the timing belt at nearly 90,000 kilometers?
Is the 2013 automatic Kia Sportage equipped with a timing belt or a timing chain?
4Does the Mazda 5 use a timing chain or a belt?
5Is the timing on the 2017 1.4T Jeep Renegade a chain or a belt?
6How many kilometers should the timing belt of the V97 be replaced?
7Is the 2013 model using a timing belt or a chain?
8How often should the timing belt and accessory belt be replaced on your Santana?
9Is it necessary to replace the accessory belt when changing the timing belt?
10Does your car have a rattling noise in the timing belt area? I went to the 4S shop and they said it's nothing. 🤥🤥🤥
