3.0 Partner Edition. There's a noise near the engine at idle, but it disappears at 1000 RPM. Can any fellow car enthusiasts tell me what might be the cause?
Whose car idles at 1000 RPM when warming up, and has anyone fixed it?
What's the idle speed of your Mazda 3 when starting cold? Mine is over 1000 RPM.
4Why does my 2008 imported Mazda 3 hatchback idle at 1200 RPM during cold starts, while it's usually at 1000 RPM? How can I fix this?
5T8 idling at 1000 RPM, what's going on?
6Why is my S40 idling at 1000 RPM, and how can I bring it down?
7Hello fellow car owners, can anyone tell me what's causing the noise from the chassis of a 2015 Sportage?
8Guys, can someone tell me how all three NCs disappeared overnight??
9It's normal for the idle speed to fluctuate when you turn on the air conditioning in a 2013 1.6 manual fashion model. Sometimes the RPM might go up to around 900 or almost 1000, and other times it might be around 800. If you restart the engine and the RPM goes back to around 800, it's usually not a cause for concern.
10The 2023 model 3.0 is shaking a lot at idle, and there's a buzzing noise when starting. Does anyone know what might be causing this?
