محمد عبد له
2022-12-14 21:04
When I was driving my Toyota Yizhi with the CVT in D gear and stepped on the gas to 4000 RPM for overtaking, I suddenly felt a lack of power and then it sped up. They say this is the steel belt slipping, and driving like this can damage the transmission. I'm frustrated. What happens when the steel belt slips? Can any experts explain this?
Comments( 6 )
فهد وحيد
فهد وحيد2023-02-22 08:28
You're pressing the accelerator too aggressively. Toyota's CVT has an electronic protection system, so even if you press the accelerator hard, the gearbox chain belt won't engage abruptly. This means Toyota's CVT won't break, but aggressive acceleration is pointless.
ستار عبدالرحمن
ستار عبدالرحمن2023-02-13 00:18
Is the Toyota Yizhi's timing belt a continuous belt or a chain? If any expert knows, please share. 🙏🙏
ستار عبدالرحمن
ستار عبدالرحمن2023-02-10 00:53
Does anyone know if the four return belts of the Yizhi are connected or separate?
حسين أصغر
حسين أصغر2022-12-31 08:17
Take it easy, mine is the same way.
عمر رضوان
عمر رضوان2022-12-28 01:18
Has it been resolved? I also have that feeling.
عبدالرحمن يعقوبي
عبدالرحمن يعقوبي2022-12-15 11:38
It's not really slipping! If it truly slips, then it needs repairs! When you floor the pedal, the car's computer interprets it as downshifting. The main issue is the engine displacement is too small. 😁
Complaint about the Volkswagen Lavida new energy vehicle. Major negative review: The battery lacks a cooling function. While charging at around 100A, the Lavida only charges at 28A to 30A at a fast-charging station, making highway driving really frustrating.
I parked my Territory in the mall's underground parking. After paying the parking fee and stepping on the gas to go up, it suddenly couldn't move. The car started shaking like "tut tut tut," and it felt like something was stuck in the front. The engine seemed to lack power.
Today, while driving, the engine warning light suddenly came on. No other lights were on, but I felt the engine trembling and it lacked power. After driving for about 150 meters, during idling at a red light, the engine vibration was quite noticeable. When the light turned green and I accelerated, the trembling became more pronounced and it lacked acceleration. I pulled over immediately, waited for about 10 minutes, and after restarting, everything was back to normal. I restarted a few times afterward and everything was fine. The last time I started the car, I drove a few kilometers home and it was normal too. Has anyone experienced this issue? Does anyone know what might be going on?
I have a 2017 automatic model with 50,000 kilometers on it. Recently, I've noticed three particularly obvious issues: 1. When starting at traffic lights, even with light acceleration, I can hear the engine howling. The fuel consumption spikes to 19.9, the engine revs up to 2000 RPM, but the acceleration is very slow. 2. When driving home from work and going up the parking ramp, I often find that even with the gas pedal pressed, there's no power. The RPM goes up to 3000, and the fuel consumption also spikes. 3. Occasionally, when starting the car, it will shake and then stall by itself. Overall, driving at speeds between 0-40 is uncomfortable, but things improve above 60, especially on the highway. Acceleration and overtaking are fine at higher speeds. It's quite frustrating. Is anyone else experiencing the same issues?
Is the CVT in the Setus a steel chain or steel belt? The 7.99 version only lacks those two LED lights, right? It still uses halogen lights. I was initially considering the new TuYue 799 version, but when I saw that even the spare tire was downgraded, I was immediately discouraged. Now I'm looking at the Honda Binzhi and Setus. The Binzhi is 10,000 more expensive, so I'm considering the Setus. The only concern is why the headlights are still halogen.
