When going downhill in a Yizhi and pressing the brakes, the RPM automatically increases, which is really annoying. Is there a way to adjust this? Do any fellow car enthusiasts have a solution?
Comments( 7 )
Hello fellow car enthusiasts, I just bought a Navara. I noticed that the reverse camera image shows things a bit farther away, but in reality, they're much closer. Is there a way to adjust it to appear closer? I'm not quite used to it!
I've been driving for two days without choosing carbon ceramic brakes, and it feels like I have to press the brakes really deep to stop the car. Do any other owners feel the same way?
I want to ask fellow car enthusiasts, what could be the cause of a jerking sensation when pressing the accelerator?
4Why can't the Pajero burn out when the brake is fully pressed and the accelerator is fully pressed in D gear, with the RPM only reaching a bit over 2000?
5When driving, if the car suddenly doesn't respond when you press the accelerator, and even flooring it doesn't increase the RPM, but releasing and pressing it again solves the issue, this could be a problem. When starting on a steep slope, if the car feels powerless and sometimes can't climb, requiring several attempts to increase RPM, there might be an issue to address.
6Hey fellow car enthusiasts, does anyone else feel that the brakes on the Eclipse Cross are a bit sluggish?
7Is the lumbar support of the standard 14-way seats on the 992.1 unable to fully retract into the backrest? Even when adjusted all the way in, it still sticks out and presses against the lower back. It's really uncomfortable over time.
8Hello fellow car enthusiasts, how do you adjust the headlight height on a Murano? I can't find the adjustment button.
9Fellow car enthusiasts, have you ever experienced the brake pedal bouncing back a few times when you press it down?
10Hello fellow car enthusiasts! Does anyone else feel that the steering wheel in the 2017 Jetta automatic is particularly heavy? Any solutions to this?
