ميثا نايف
2022-12-05 23:01
What could be the issue if the air conditioning compressor keeps running even when the AC switch is properly turned off? Does anyone know?
How to turn off the automatic air conditioning?
Why does the air conditioning compressor keep making noise for a few minutes after parking and locking the car? What could be the reason?
How can I manually turn off the air conditioning? I always have to tap on the screen to turn it off.
Why does the air conditioning keep turning on and off at idle in first gear?
When I turn on the air conditioning, the cooling fan starts spinning, then stops after a while. The cycle of spinning and stopping is roughly one minute. Even after turning off the car, the fan keeps running and won't stop. Only by restarting the car and then turning it off again does the fan stop. Could the temperature sensor be malfunctioning? Any insights from the experts?
When the air conditioning is turned on in the 3008, it triggers an alarm, but it goes back to normal when the AC is turned off. What could be the problem and how can it be resolved?
Hey guys, the AC isn't cooling and is blowing hot air. When I turn on the AC, the compressor doesn't work, even though it's new. The repair shop said the fuse box has a bad connection and replacing it would cost over a thousand. What should I do?
What could be the cause of the Mazda 6 air conditioning compressor frequently cycling on and off and making loud noises?
