خالد نعمان
2023-10-08 09:27
The Toyota Yizhi 1.8-liter engine uses a timing chain.
خالد سليمان2023-10-08 11:05
Chain. Isn't it better for Toyota to not use belts?
The Iveco Daily 3.0 engine uses a timing chain.
Is the 2013 automatic Kia Sportage equipped with a timing belt or a timing chain?
Does the Mazda 5 use a timing chain or a belt?
4What's the fuel consumption of the 1.8-liter engine in the lift-up model? How does it affect the engine? Is it stable?
5Does the water pump for the 1.8 Yizhi from the 12th edition match with the one for the Corolla?
6The Toyota Yizhi 1.8-liter engine uses a timing chain.
7Is the 2013 model using a timing belt or a chain?
8Will the timing chain of the 2017 automatic luxury version engine stretch?
9The engine in the Iveco Ousheng 2.0 uses a timing chain.
10Has anyone replaced the high-pressure fuel pump and timing chain on a 1.6L engine?
