أحمد نواف
2022-05-18 22:09
The steering wheel of the 2016 Crossover Yizhi is not aligned properly and is tilted to the left. The left side is further from the driver, and the right side is closer. Has anyone else experienced this issue, and is there a solution?
عبد العزيز زيد
عبد العزيز زيد2022-10-23 10:48
Add some punctuation, please. 😄😄
عبدالله فرج
عبدالله فرج2022-10-09 08:40
Just do a wheel alignment.
أبو بكر محمد
أبو بكر محمد2022-05-19 21:33
Four-wheel alignment or wheel balancing.
I bought a used Yizhi car and found a camera under the right side mirror. Does anyone know how to turn it on?
Is the fog light above the taillight on the left side only and not on the right side for the Sienna Platinum version?
I've noticed that the two air vents under the main driver's seat in my ASX tend to blow cold air on the left foot. Not sure if other drivers have experienced the same issue. I tried blocking it with tissue paper, and it seems to help a bit. Any other good solutions from fellow drivers?
Can I plug a home charger into the fast-charging port on the left side, considering that my parking space has more room on the left and the right side is against the wall?
Is the hood of the Grand Cherokee lower on the right side? When sitting in the driver's seat and the passenger seat, the hood seems to have different heights. From the passenger seat, the right side of the hood appears to have a greater curve, but from the driver's seat, the left side doesn't seem to have as much curve as the right. The car is parked on level ground, and the seats are adjusted the same, but the issue persists. However, when viewed from outside the car, there seems to be no problem. Is this a visual perception issue?
Hello fellow car enthusiasts! Why is the reverse camera on my 2013 Sharan 2.0T showing the left and right sides reversed?
Hey Swift buddies, can someone tell me where the water leak is if there's water accumulating under the rear seat on the driver's side during rainy days? There's no water anywhere else, just this spot on the left side of the rear seat.
Is the automatic anti-glare function for the exterior rearview mirrors on all Ford models only available on the driver's side, but not on the right side?
Has anyone done a wheel alignment? My City has uneven wear on the left rear tire and slightly pulls to one side. I've heard that the City’s rear wheels are non-adjustable and you can only add shims during alignment. Is this safe? Also, is it necessary to do a wheel alignment since the tires are quite cheap? 🤦‍♂️
