خالد أرسلان
2022-06-27 12:30
Should I change the transmission oil for my 2012 Yizhi? It's almost 70,000 kilometers! Recently, I've been feeling some jerking while driving.
Comments( 13 )
حسين تاج
حسين تاج2022-10-27 08:22
Sure, you can change it.
سلمان خديجة
سلمان خديجة2022-07-18 13:31
There are jerks, you can replace it.
محمد ميرزا
محمد ميرزا2022-07-05 12:44
Change the automatic transmission fluid every 60,000 kilometers.
خالد زاهر
خالد زاهر2022-07-05 10:49
It seems like the manual says it's maintenance-free...
خالد أرسلان
خالد أرسلان2022-06-29 18:43
The engine oil was changed, but the filter wasn't replaced!
نايف ق
نايف ق2022-06-29 12:50
Changing the oil of a FAW Toyota and replacing the filter can improve fuel economy.
خالد أرسلان
خالد أرسلان2022-06-28 19:23
I often drive on mountain roads! Maybe there's a lot of wear and tear.
حسين خليف
حسين خليف2022-06-28 19:01
I exchanged it for 120,000, and the result was neat and clean.
خالد أرسلان
خالد أرسلان2022-06-28 09:56
Gravity change or machine change?
فهد نوري
فهد نوري2022-06-28 09:31
It needs to be replaced, the jerking sensation is generally caused by dirty oil leading to a stuck transmission valve body.
How do you guys change the transmission oil for your Ruixing? I changed my transmission oil at 200,000 km, and now it's almost 260,000 km. When I accelerate at low RPMs, there's a noticeable jerk and drag, like it's getting stuck.
Is the jerking in the 13 model caused by needing a transmission oil change? I've never changed it in over 90,000 kilometers. 🤦‍♂️
I've been driving a 2015 ASX and need some advice. The car starts just fine, but once I pick up speed and then suddenly brake to slow down, when I press the accelerator again, it feels like there's no response at first. There's a sudden jerk before it accelerates, making the driving experience really bad. Could it be time to change the transmission fluid? It's been 7 years and 45,000 kilometers, and I haven't changed the transmission fluid yet.
Hello everyone! A while ago, I posted about the jerking and hesitation during low-speed starts. Recently, I found some information online suggesting that the 6-speed wet dual-clutch transmission, model DCT360, from SAIC had design flaws. Is this the transmission model used in the MG HS 2.0T? If it is, does the issue of the car not moving with light acceleration and jerking with heavy acceleration count as a common problem due to design flaws? If not, is there any way to resolve it?
Does the 2019 model with 1.4T engine need a transmission oil change at 60,000 kilometers? Some say it's maintenance-free, while others say it needs to be changed. I'm not sure what to do. Have any of you changed it?
Do I need to change the transmission oil for a 2019 GAC GS5 Elite version with 70,000 kilometers on it?
How often should the spark plugs in the 2019 GS5 be replaced? It's approaching 70,000 kilometers and hasn't been changed yet.
Hey car enthusiasts, has anyone never changed their CVT transmission fluid? Mine's been 6 years and almost 80,000 kilometers. I'm not sure whether to change it or not. Some say you don't need to, and changing it might actually cause problems. But I'm also worried about not maintaining it properly. Any advice?
