فهد حرب
2022-10-06 20:02
My Yizhi is a 2011 model produced in 2013. The chassis is quite stable, but the driving experience is too stiff due to the suspension. Any experts have tips to solve this?
سلمان ربيع
سلمان ربيع2022-10-16 21:40
In June, I replaced my car's shocks with KYB black ones from Tuhu. I used them for 3 months before selling the car, so I took them off. I originally bought them for almost 600, now selling for 400.
حسن بدر
حسن بدر2022-10-16 00:45
I also hear a creaking noise from the back when going over bumps. I think it might be an issue with the stabilizer bar bushings, but I haven't had the time to check it out yet.
حسين أصغر
حسين أصغر2022-10-14 11:37
Replace the shock absorber.
The suspension of the Chuan Yue Zhe is quite stiff. Can anyone recommend a good suspension for me? Thanks.
Hey everyone, the chassis of the GV80 feels too stiff, and the ride comfort is really poor and bumpy. The roads I'm driving on aren't even that bad. It seems like having no air suspension is really an issue. Any suggestions?
My Peugeot 207's suspension feels quite stiff. Is there something wrong? Has anyone else experienced a similar issue with their car? I have a 2013 Peugeot 207 sedan.
I’ll share my personal test drive impressions of various SUVs in the same price range. Can anyone explain the difference in chassis feel between the GV70 Flagship and Luxury models? If there's someone who has driven both, please provide detailed insights! I've also tried SUVs of the same class like BBA, Volvo, and Jaguar. Personally, I think the new GLC has the best overall chassis quality, with Genesis coming in second. Genesis has the best sound insulation! The throttle response is the worst on the GLC! The X3, Q5, Genesis, Volvo, and Jaguar feel quite similar. Subjectively, the GV70 ranks in the top two for overall comfort and drivability. PS: The Q5 feels more filtered and softer. The X3 is a bit too ground-hugging and follows the road surface too much, which I don't like. Volvo is in the middle, but it has the worst sound insulation in its class! The GLC's chassis quality is great with a solid, integrated feel, but the throttle response is really lacking! The Jaguar F-Pace has a slightly firmer chassis and a more sporty driving feel, but its downside is average noise control with some resonance, and it has the smallest rear space. Genesis offers the best overall driving experience. Even with 21-inch wheels, the suspension is really excellent, and the power delivery is smooth and responsive. The space is similar to the X3.
I bought a second-hand 2013 2.0 Peugeot 3008, and I feel like the rear suspension is really stiff. What can I do about it? Going over speed bumps makes people bounce up. Any advice from experts?
