يعقوب سعود
2021-10-02 21:29
My 2011 Comfort version has the AC on all the time, usually set around 26°C! The fuel consumption is around 10 liters. I hardly use the sport mode. Is there any way to reduce it to the 7-8 liters you guys mentioned? (I'm planning to change the engine oil to 30, as well as the transmission oil and spark plugs soon.)
Comments( 10 )
عبد العزيز برهان
عبد العزيز برهان2022-07-09 23:48
You changed it just like mine. I just replaced it, and it feels really comfortable to drive.
عبد العزيز برهان
عبد العزيز برهان2022-07-09 23:47
I'm using 30 motor oil.
عبد العزيز برهان
Resetting the fuel consumption will restore it to normal.
محمد عَبْدُ الله
محمد عَبْدُ الله2022-07-09 21:59
Same fuel consumption [I want some peace]
خالد زاهر
خالد زاهر2022-07-05 10:51
The engine oil is 20, but mine has been 7.5 for a long time. I drive aggressively, usually at a speed of 130-140 km/h on the highway.
خالد عبد الوهاب
خالد عبد الوهاب2022-07-03 22:34
Since I bought it, the overall fuel consumption has consistently been between 8.1-8.4, calculated by myself after a full tank. It's a 1.8-liter engine.
حسن أصغر
حسن أصغر2022-07-01 01:11
110,000 kilometers, fuel consumption is consistently 7.8-8.0. It's a 1.8 naturally aspirated engine.
نايف ق
نايف ق2022-06-29 12:55
Changing the transmission oil to Toyota's might reduce fuel consumption a bit.
علي عائشة
علي عائشة2022-03-27 18:12
My previous fuel consumption was 7.4, now it's 7.8. I often drive in mountainous areas and the city, and occasionally on the highway.
حسين زيد
حسين زيد2021-10-04 16:46
My long-term fuel consumption is maintained at 6.8-7.0. High fuel consumption is mainly due to short-distance driving, where the engine doesn't reach normal temperature and gasoline doesn't burn completely, leading to carbon buildup. For short distances under 5 kilometers, it's better not to drive. Consider using ride-hailing services like Didi, or opt for buses and the metro.
Maintenance guide for the 2007 Opel Astra: 1. **Regular Oil Changes**: Ensure you change the engine oil and oil filter every 5,000 to 7,500 miles to keep the engine running smoothly. 2. **Brake System Check**: Inspect brake pads and discs regularly, approximately every 10,000 miles, and replace them as needed to ensure safety. 3. **Tire Maintenance**: Check tire pressure monthly and rotate tires every 6,000 to 8,000 miles to ensure even wear and prolong tire life. 4. **Air Filter Replacement**: Replace the air filter every 15,000 to 30,000 miles to maintain optimal engine performance. 5. **Coolant Level**: Check and top off the coolant level regularly to prevent the engine from overheating. 6. **Battery Check**: Ensure the battery terminals are clean and the battery is functioning properly, especially before winter. 7. **Transmission Fluid**: Inspect and, if necessary, replace the transmission fluid every 30,000 to 60,000 miles to ensure smooth gear shifts. 8. **Spark Plugs**: Replace spark plugs every 30,000 miles to maintain fuel efficiency and engine performance. 9. **Suspension and Steering**: Regularly inspect the suspension and steering components to ensure a comfortable and safe ride. By adhering to this maintenance schedule, you can help ensure your 2007 Opel Astra continues to perform reliably.
Your 2016 model X3 with the Smart Connect 3 joy gear consumes about 6.6 liters per 100 km on the highway, around 7 liters in the city, and approximately 8 liters on mountain roads. Is this normal?
I have a 2021 2.0F1A manual Euro Victory, and when I shift from 2nd to 3rd to 4th gear and accelerate, there's a clicking sound between 1100 and 1400 RPM, like it's low on oil. Does anyone else experience this? Once the RPM reaches around 1500 and the turbo kicks in, the sound starts to decrease. The 4S shop upgraded the ECU, but the sound is still there, whether the AC is on or off.
For a 12-year-old car that has already run 190,000 kilometers and is experiencing a lack of power when starting, it's generally recommended to use a high-mileage engine oil. High-mileage oils are specially formulated to help reduce oil consumption, minimize leaks and oil seepage, and reduce smoke and emissions in older engines. They also contain additives that help condition seals and protect worn engine parts. You might want to consider a 10W-40 or a 5W-30 high-mileage oil, depending on your climate and specific engine requirements. Always refer to your vehicle's manual or consult with a professional mechanic for the best advice tailored to your car's condition and needs.
For the 2016 Vitara automatic two-wheel drive Elite version, it's generally recommended to use 5W-30 engine oil. If you just changed the oil and noticed a one-liter increase in fuel consumption, it might be worth checking if the oil type and specifications are correct for your engine.
For a newlywed couple from 1997 considering their second car with a budget of 30-40, it's a tough choice between experiencing smart driving with a new electric car or going for a used Porsche 718 for around 30. Since you don't have kids yet, it might be the perfect time to enjoy a sports car. 😄
