How is the performance of using NGK spark plugs in the Yizhi?
What spark plug model should be used for a 2014 Suzuki Grand Vitara with a 2.4 engine?
Is the original spark plug of the F150 made of double iridium material?
4Hey guys, at how many kilometers did you change your spark plugs? 😎
5I've driven nearly 40,000 kilometers and I'm thinking about changing the spark plugs. Which model should I choose between Bosch and NGK? I saw a Bosch double platinum spark plug online. Is it necessary for this car to use double platinum?
6The original spark plug failed after just over 10,000 kilometers. How about you guys?
7Car enthusiasts, which brand of spark plugs do you recommend? Is everyone using Mitsubishi NGK single iridium spark plugs?
8How often should the spark plugs in the 2019 GS5 be replaced? It's approaching 70,000 kilometers and hasn't been changed yet.
9Is there any oil seeping into the cylinder from the spark plug? Should this be addressed?
10I'm thinking about changing my spark plugs recently. What brands do you guys use?
