حسين أصغر
2022-10-14 12:11
Hey folks! Anyone else experiencing this with their Yizhi? What's the issue with the idle speed fluctuating when starting a cold car? Sometimes it hits 2000 RPM right after starting.
عبدالرحمن يعقوبي
عبدالرحمن يعقوبي2023-01-24 10:34
That's how petrol cars are! It'll be fine in a bit. 😄
سلمان نوري
سلمان نوري2023-01-22 23:54
This issue is normal. Mine does the same. After starting the car, it warms up for a bit, and then it's okay.
علي عفان
علي عفان2023-01-22 16:35
Cleaning the throttle body.
عبد العزيز زيد
عبد العزيز زيد2022-10-23 09:55
When the car is new, the RPM is high for a while when it's cold. Even when you shift gears and give gas, it doesn't move much. After warming up, it gets better; the sound and RPM go down, and it moves easily when you shift and accelerate.
حسن بدر
حسن بدر2022-10-16 00:44
My car also starts directly at 2100 RPM.
Why does my 2008 imported Mazda 3 hatchback idle at 1200 RPM during cold starts, while it's usually at 1000 RPM? How can I fix this?
Is anyone else experiencing unstable idling with the new BRZ? Even without the AC on, whether the car is cold or warm, the gauge needle fluctuates noticeably.
Just got it, the engine idle speed fluctuates when cold. Any fellow car owners experiencing this?
Is it normal for the Yizhi to have an RPM of 2500 during a cold start in the morning?
It's normal for your NV200 to have a high idle speed of 2000 RPM when you start it cold, and then drop to 800 RPM after about a minute. This process helps the engine warm up. However, if it feels inconvenient, you might want to consult a mechanic to see if any adjustments can be made.
I just got a 2013 model with a 1.6 manual transmission. Everything else is fine except there's a loud buzzing vibration sound around 2000 RPM in every gear. Before or after hitting 2000 RPM, it's normal again. Has anyone else experienced this? How can it be fixed? Any advice from the experts would be appreciated.
When starting a cold car, the RPM goes up to 2000 and then drops to 1500 but doesn't go any lower. The high idle speed is causing high fuel consumption, 20 liters for 300 kilometers! The idle speed is too high, and so is the fuel consumption. Can any experts provide a solution? 🙏
When I start the car, the idle speed is around 2000 RPM, but after a while, it drops to 1500 RPM. It takes quite a long time to go down to around 1000 RPM. Does anyone know what's going on?
Does anyone else experience their engine roaring at 2000 RPM?
