سلمان عوض
2024-10-22 09:16
This is a car with severe tire wear and steering misalignment after only 50,000 kilometers. What car is this?
I've been using the 2017 MDX for over a year, and the front tires are wearing out unevenly. After rotating the rear tires to the front and doing an alignment, the newly replaced tires are again showing severe uneven wear. Have any other car owners experienced this situation? Looking for advice.
I'm looking for advice on my 2016 Volkswagen Multivan 4WD that's experiencing severe tire wear. I've done a wheel alignment, but it hasn't resolved the issue. Any insights would be appreciated.
How to reset the tire pressure on an F150 after patching the tire? [what][what]
My car's engine light turned on after driving over 50,000 kilometers. Does anyone know how to turn it off?
1.5T manual transmission, 2016 model, 50,000 kilometers. Spark plugs were replaced at 42,000 kilometers. Today, the car suddenly stalled, and after restarting, it stalled again after driving for a while. Can any experts help figure out what the problem might be?
I have a 2018 V40, and when I start it, the steering wheel and the center console panel shake a lot, especially when I turn on the air conditioning. It's only run about 50,000 kilometers. It takes quite a while for the shaking to reduce. What could be the problem? Has anyone else experienced this?
What is the current market situation for a 2018 T3 with 50,000 kilometers, in white?
Have you guys changed your tires around 50,000 km? If so, what did you switch to?
Hey experts, I'm nearing 50,000 km. What tires would you recommend?
Are there any fellow drivers experiencing severe rear tire wear? After 30,000 kilometers, the rear tire treads are down to the warning line...
