خالد غازي
2024-10-31 14:00
My 2023 2.5 Hybrid 4WD Supreme Flagship model loses power overnight for some reason. Does anyone else have the same issue?
خالد غازي
خالد غازي2024-10-31 19:58
I don't know, I'll go to the 4S shop for a check tomorrow.
عمر كم
عمر كم2024-10-31 19:45
Is the battery broken?
Possible reasons for the acceleration issue with your 2014 2.5 4WD Renault Koleos could include: 1. Engine issues such as clogged fuel injectors or a dirty air filter. 2. Transmission problems affecting power delivery. 3. Faulty sensors like the mass airflow sensor or oxygen sensor. 4. Exhaust system blockage. 5. Fuel system issues impacting fuel economy and power. It's recommended to have a professional mechanic diagnose the problem for an accurate solution.
Fault code P0504, currently gears 1, 2, 3 are fine, but when switching to 4th gear, the car loses power when pressing the accelerator and doesn't accelerate. The RPM drops very slowly when pressing the clutch. Has anyone else experienced this?
I have a 2018 2.0 4WD Jeep Renegade. When I start the car, while the gear is in the P position and I press the brake, I hear a clicking sound from the gear area. Has anyone else experienced the same issue?
Honestly asking, what is a reasonable discount for the 2023 HS7 Flagship 4WD Seven-Seater?
Why do I feel a strong drag when I release the accelerator? Does anyone else experience this? I have a 2024 Forester 2.5 with less than 1000 kilometers. What could be the reason? Looking for advice.
When driving, sometimes when I press the accelerator, I feel a jerk, like there's suddenly no power, and then it's fine again. What's going on? Does anyone else have the same issue?
It's unrealistic to get a 2023 model year 6-seater 4WD Red Flag HS7 with a 2.0+48V mild hybrid for 160,000 yuan.
I have a question for the owners of the 4WD version of this car. Today, I asked a friend if setting the 4WD selector to 2WD on the Outlander Sport makes the fuel consumption the same as the 2WD version. He said no, even if you set it to 2WD, there's still some power loss, and the fuel consumption is higher than the pure 2WD version. Is that true, folks?
What are the differences between the Avalon Hybrid 2.5 and the ES300h hybrid? It seems like the exterior dimensions and powertrain are the same. Could someone with more experience explain this in detail? I'm a newbie.
Has anyone bought the Asian Lion 2.0L hybrid? How's the fuel economy and power? It seems to have the same engine as the Asian Dragon 2.0L hybrid.
