فهد منذر
2023-06-27 20:49
How do you deal with this JBL sound system? The Bluetooth connection is really bad, and using a USB drive is only slightly better. You'd think with 9 loudspeakers, it wouldn't be this bad. And there's no CarPlay amplifier. How did you guys solve this?
Comments( 7 )
عبدالرحمن فؤاد
عبدالرحمن فؤاد2024-10-05 08:53
Use Apple Music, everything else is trash.
نايف صادق
نايف صادق2024-10-03 22:01
Just replace the DSP; the original one can't drive it.
عبدالرحمن رشيد
عبدالرحمن رشيد2023-06-28 12:06
No, I am using it just fine.
خالد نجيب
خالد نجيب2023-06-28 09:16
It also depends on your music format. It's best to use a USB drive with FLAC format music for better quality.
حسين احمد
حسين احمد2023-06-28 07:49
Install soundproofing for the entire car, replace the set of loudspeakers, and add a multi-channel DSP.
عمر كم
عمر كم2023-06-27 22:02
Is it an issue with your phone signal? I didn't notice anything. [I want to be alone]
عبد العزيز منتصر
عبد العزيز منتصر2023-06-27 21:36
Why don't you buy a loudspeaker to play with? A car is meant for driving. 😄
Is your CarPlay music playback smooth? How do you fix any issues? Also, the automatic lock/unlock feature sometimes doesn't work properly, which is frustrating. Additionally, after turning off the engine, the power cuts off immediately, so I can't close the windows if I forget. Lastly, when starting the car, I have to manually turn on the central control. Is this a settings issue on my part? How do you all deal with these issues? Or am I the only one experiencing them?
My Peugeot 207's steering wheel is a bit off, and I have to turn it slightly to the right to drive straight. Has anyone else experienced this? How did you deal with it? Any advice would be greatly appreciated. 🙏🙏🙏!
Hello fellow car enthusiasts! How do I get CarPlay on the G70? My wife uses an iPhone and wants to use CarPlay. Do I need to buy some kind of CarPlay box from an online store? Any recommended shops? How have you guys solved this issue?
