فهد عابدين
2024-10-01 12:13
Has anyone here modified their car or changed tires? My left front tire got a nail in it and can't be repaired. I've been asking around but can't find a Toyo 225 55 R19 tire, and with the national holiday, I can't replace it until the 4th. It's really inconvenient. Has anyone switched to other tire brands after buying their car? Any recommendations? I'm hesitant to replace just one tire with a different brand, and since I need the car urgently, I'm considering replacing both front tires.
عمر كم
عمر كم2024-10-01 14:20
"I just want some peace..."
My RDX has hit 90,000 kilometers, and the dealership also suggested replacing the tires. I wonder which tire models everyone else has switched to? Feel free to share the specific brands and models! Tires with the same specifications for other cars are also welcome, like 235/55R19. 👍
Can the front wheels be replaced with 255/50/19 tires? Will it affect steering or rub against the inner lining?
Are you guys replacing your Yige's tires with the original ones or going for other brands?
What brand of tires should I use for the front wheels of a 453? The size 165/65R15 is indeed rare. Thanks.
Are there any affordable 20-inch tires that fit the 718T? Specifically, front 235/35R20 and rear 265/35R20? I can't afford PS4 and PZ4 anymore.
I only replaced the front two tires, not the rear ones, and they're from two different brands. The tread patterns are quite different, and the load capacity and speed ratings aren't the same. Is this okay? Is there any risk? Do I need to replace the rear tires as well?
My Kodiaq's rear tire is wearing unevenly, with noticeable wear on the inner side. The repair shop says I need to replace the lower arm because it can't be adjusted, and then do a four-wheel alignment. Is this the case?
Hey guys, what brand are the original tires? What brand do you all switch to for replacement?
Hey folks, planning a two-month road trip starting from the National Day holiday. If I get a flat tire along the way, what should I do? My Peugeot 2008 doesn't have a spare tire. What's all that stuff under the trunk for?
