Every time I accelerate from a stop with my 2.0, there's a sound similar to gears meshing. The dealership says it's the differential noise and considers it normal. Do any fellow car enthusiasts experience this noise as well?
In early 2019, a 2.0T gasoline automatic four-wheel drive with 23,000 kilometers has a squeaking sound when idling and accelerating. It keeps making noise, but stops after letting off the accelerator. Has anyone encountered this before? Looking for solutions.
Has anyone encountered engine noise in a 2019 F150 with 60,000 km? The mechanic says it's a common issue and suggests dismantling the engine to fix the gears.
There's a noise coming from the transmission, but when I press the clutch, it stops. The dealership said it's an issue with the clutch disc, and they've already replaced it. But the problem still isn't solved!
4Is there a good way to fix the plastic noise in the gear shift of the 2019 Classic Sylphy? I've been to the dealership four times, but they haven't fixed it!
5Is it normal for the accelerator pedal to make noise? I've had this issue since I first got the car, and it's really annoying. The dealership says it's normal. Fellow car enthusiasts, is this really normal?
6Is there anyone who has experienced a similar issue with the 2017 Dongfeng Renault Koleos 2.0 making a squeaking noise when turning the steering wheel? I went to the repair shop and they said the steering gear needs to be replaced. How did you solve it?
7I have a Mini Clubman 2.0T, and when starting or at low speeds, I hear a kind of loose rattling sound, similar to a "license plate not tightened" noise, when I press the accelerator. I'm not sure where the sound is coming from. Does anyone else with a Mini experience this?
8Did anyone with the 2021 Cayenne experience similar noises? 1. There's a sound similar to backfire when the engine stop-starts cold. 2. There's a noise when braking, even after replacing all four brake pads and discs. It's a screeching sound, quite piercing, like a large truck's brakes. 3. The sunroof screen and sunshade have been making noise since I got the car, and it hasn't been resolved. Anyone with the same issues? Any solutions? Looking for help.
9Every time I accelerate from a stop with my 2.0, there's a sound similar to gears meshing. The dealership says it's the differential noise and considers it normal. Do any fellow car enthusiasts experience this noise as well?
10My car is a 2.0 naturally aspirated engine. When I gradually accelerate past 80 km/h, the car shakes a few times, and then it stops shaking. However, if I press the accelerator hard, this doesn't happen. I wonder what's causing this.
