After driving the Venza over bumpy roads, there's always a strange noise coming from the trunk, like something is rubbing or hitting against each other. The same noise happens when turning or going over speed bumps. I've removed all the tools from the trunk and taken off the plastic covers, but the noise is still there.
The 2014 Model S P85 makes a rattling noise from the right side of the chassis when going over small bumps, manhole covers, and speed bumps. I've already replaced the control arms, but the noise is still there. Does anyone else have the same issue? How can it be resolved?
Is there a clunking noise from the front left when driving on bumpy roads? Has anyone experienced this issue?
4I'm wondering if anyone knows what might be causing a noise from the rear wheels of a 2006 4Runner when going over bumps?
5It's uncomfortable going over speed bumps, it's very bumpy. What's up with the suspension?
6When driving over bumpy roads, there's a suspected noise coming from the chassis around the rear axle area (a creaking sound). I want to ask if anyone else is experiencing this too?
7Can the rubber bushings be replaced? The car makes a lot of noise when driving over bumpy roads.
8Is there any car owner experiencing a noise from the right rear wheel? When the temperature is low, there's a squeaking sound when going over speed bumps. There's no abnormality during normal driving, and it doesn't make noise on bumpy roads. The shock absorber isn't leaking either. The car is only three years old, so it shouldn't be the stabilizer bar bushing issue, plus the sound doesn't seem like it's from the stabilizer bar bushing.
9How can I fix the squeaking noise from the middle door when driving over bumps? Does anyone else have this issue with their car?
10After driving the Venza over bumpy roads, there's always a strange noise coming from the trunk, like something is rubbing or hitting against each other. The same noise happens when turning or going over speed bumps. I've removed all the tools from the trunk and taken off the plastic covers, but the noise is still there.
