حسن فريد
2024-06-27 11:21
The child lock on the right rear door of the 2014 V60 is not engaged, but the door cannot be opened from the inside, only from the outside. What could be the issue?
فهد إسحاق
فهد إسحاق2024-06-27 14:33
The lock is broken.
I bought a Kia Sportage in 2010, and suddenly the right rear door won't open. What could be the reason? It's not the child lock issue. Also, the door handle feels loose when pulled.
How do you unlock the child lock on the 19zs rear door? It's annoying that the door can only be opened from the outside.
During the rainy season, typically from April to August, the car doors cannot be opened from inside or outside, while they function normally at other times. Could it be that the lock mechanism is affected by moisture on rainy days? What might be the issue here? Experts, please help! Thank you!
I have a 2019 model car and after I activated and then deactivated the child lock on the rear right door, it can't be opened from the inside anymore, only from the outside. Has anyone experienced this? How did you solve it?
Does the Peugeot 3008's automatic door lock still allow the doors to be opened from the inside? Is this normal? What solutions are there? Otherwise, it really doesn't feel secure.
Why does the driver's door not open with the key unlock button after locking the car from the outside, while the other three doors can be opened?
Can you open the car door directly from the inside while driving, is it always like this?
Why won't the right door open suddenly? Is it the child lock? Where's the child lock switch?
The rear door of the Jetour X90 Zilong Edition cannot be opened from both the inside and outside.
Volvo Volvo V60
Volvo V60TBDPetrol
