خالد عين
2024-09-29 17:58
Is there any owner who has experienced a clunking noise from the chassis when making a U-turn with the steering fully turned? I went to the 4S store, and they said it's a problem with the half axle and needs replacement. Has anyone else encountered this?
Has anyone in the group experienced this issue with a 2019 Patrol, 4.0 Middle East version, after 70,000 km? When switching between D and R gears, there's a noticeable clunk from the chassis. It drives fine on the road, but when changing from forward to reverse, there's a distinct clunking sound.
Hello fellow car enthusiasts, has anyone installed coilover suspension on their car? Can it improve the chassis feel? My car is a 2017 4WD Elite with over 90,000 kilometers. When I go over speed bumps or drive on rough roads, the chassis makes a clunking noise. Will installing coilover suspension help?
Taurus chassis noise I have a 2019 Taurus, bought in 2021, and it's now at 57,000 kilometers. Recently, there's been a serious noise coming from the chassis, and it gets worse as the weather gets hotter. When the vehicle goes over speed bumps or when the front wheels hit uneven road surfaces at different times, there's a squeaky sound from underneath, like metal rotating inside a rubber bushing. When entering the garage and turning the steering wheel left, there's a clunk noise from the front when the front wheels hit a speed bump. The same clunk noise happens when parking with the steering wheel fully turned while reversing. The noise is very uncomfortable. Any suggestions from fellow car enthusiasts? Has anyone else experienced this?
Has the chassis of the 2025 model been made stiffer? I've searched a lot, and the old models are often said to be too soft, like driving a boat.
2018 Peugeot 308 1.6L has a clunking noise when turning the steering wheel. Replaced two shock absorbers and the left strut mount bearing, the noise reduced but it's still there.
Is there any Land Rover Defender 110 owner who has experienced a clunking noise and vibration from the rear wheels when turning?
Has anyone experienced this? I went to the 4S shop for the second maintenance of my GS8 fuel version, and they required adding a fuel system cleaner. They said it's mandatory according to manufacturer regulations.
I've had my car for over a year, and the auto start-stop has never worked. I went to the dealership, and after a test drive, the service staff said it works, but I need to turn off the AC for it to function. I've turned it off, but it still hasn't activated. How do you guys use it?
I've got a 2013 Forester and I'm hearing some clunking noises from the chassis. I already replaced the steering rack, but the issue is still there. I'm thinking about changing the shocks next, but the specialist said it's not necessary and that this noise is something the car has had since it was made. Has anyone else experienced this issue? Any advice?
Volvo Volvo V60
Volvo V60TBDPetrol
