I've checked the high and low beam lights outside the car, and they can be turned on and off normally. However, when I switch to the high beams, the dashboard keeps showing a "high beam fault," whereas there is no fault reported for the low beams. Can any experts advise on what exactly might be the problem?
What's the model for the high and low beam bulbs of a Liana? Anyone knows? 😊
How do you turn on the high beam for the 206? The low beams can be turned on and the high beams can be activated by pulling the switch back, but it can't be pushed forward. What's going on?
How can I adjust the high and low beam headlights inside the car?
4How do I adjust the low beam height on a Peugeot 207? It's too high and keeps blinding other drivers at night.
5The dashboard reported low transmission performance, and then the car wouldn't accelerate. After restarting, the warning light went off and it drove normally. What could be the reason? (The onboard computer cleared the fault light, but it came back on before I got home.)
6Does anyone know why the high beam and low beam headlights keep breaking?
7What is the wattage of the automatic headlights on the 2019 MG ZS, and are they integrated high and low beam?
8Who knows how to turn off adaptive high beams? I set it up and found that when I manually turn on the low beams, the dashboard indicator light goes off, and I still can't figure it out.
9I've checked the high and low beam lights outside the car, and they can be turned on and off normally. However, when I switch to the high beams, the dashboard keeps showing a "high beam fault," whereas there is no fault reported for the low beams. Can any experts advise on what exactly might be the problem?
10For a 2012 Kia Sportage with integrated headlights, if adjusting the low beam to the right position causes the high beam to point at the treetops, does anyone know how to solve this? How can the high beam be adjusted lower without moving the low beam?
