أحمد عباس
2024-04-25 09:00
I have a 2017 V60, and sometimes I hear a clicking noise from the chassis when driving at high speeds. The noise disappears if I lightly tap the brakes. I suspect it might be an issue with the brake system, but I've been to the dealership twice and they couldn't solve it. Has anyone experienced a similar problem? Any solutions would be greatly appreciated!
فهد إسحاق
فهد إسحاق2024-04-26 14:26
Were the brake discs removed for inspection? Are the brake pads worn out? Is the engine skid plate loose or is there too much gap?
When lightly pressing the brakes on the Vellfire, there's a slight "click" sound. Has anyone else experienced this?
I have an 18-year-old car, and I just switched to an electric car this April. I've tried twice, and if I park for more than 5 days, it won't start. I suspect there's a power leak in the car. Has anyone else experienced this?
Has anyone else encountered this issue? Recently, when I activate the auto hold, after the car stops, the AVH light blinks and then there's a clicking sound. It happens every time. If I press the brake harder, the sound is louder; if I press lightly, the sound is softer.
My Peugeot 207's steering wheel is a bit off, and I have to turn it slightly to the right to drive straight. Has anyone else experienced this? How did you deal with it? Any advice would be greatly appreciated. 🙏🙏🙏!
Hey fellow car enthusiasts, I have a 2021 Jeep Compass and the brakes make a screeching sound when the car is cold, especially in the morning. The noise is quite loud. Has anyone else experienced this? Any advice would be appreciated. 🙏
For a 2013 Suzuki Swift, if you're experiencing a buzzing noise at speeds of 40 km/h and above, and the noise gets louder as you go faster, what can you do to reduce the sound? Any advice from experts would be greatly appreciated. Thank you!
Does your car have this kind of noise? The engine is making a strange sound. I suspect it's the VTC gear making noise.
I have a 2016 Haval H2. Have any of you experienced a brake light fault warning when pressing the brake pedal for a long time, but the warning disappears once you restart and press the brake again?
Has anyone experienced a noise from the front right wheel, like a screeching sound, especially when lightly pressing the brakes or driving at 20-30 km/h after braking? The noise is very sharp.
Volvo Volvo V60
Volvo V60TBDPetrol
