عبدالرحمن عبد له
عبدالرحمن عبد له
Jun 25
How do I reset the trip meter on a 2016 V60CC? I watched a video yesterday that said to press the "O" button on the steering wheel control, and it worked yesterday. But today, it doesn't respond. Any advice?
مساعد عبد العزيز
مساعد عبد العزيز2024-07-01 05:19
You can reset it from the central control, and also from the dashboard. To reset the dashboard, press the left stalk and OK to enter; all the settings are inside.
How to reset the trip meter on Ruixing?
To reset the trip meter A on a Haima S5, it's usually done with a small button on the instrument panel. If you can't find it, refer to the owner's manual for specific instructions, as the button might be less visible or located differently.
Hey guys, how do you reset the trip meter above the total mileage on the dashboard? I have a 2011 base model, manual transmission, 1.4L hatchback.
How do I reset the trip meter after maintenance on a V40?
Stainless steel shell thickness: 1.8mm for the four doors, 1.4mm for other parts. I was quite puzzled after watching a video of the actual car this year; it didn't seem to match the 3mm thickness mentioned in 2019. Today, I just saw a video explaining the official version of the sheet metal thickness.
In a 2019 manual vehicle, if the steering wheel buttons suddenly stop working and after resetting and reconfiguring, the buttons still don't respond, what could be the reason?
How long is the warranty for BYD charging stations? I recently bought a BYD electric vehicle. A few days ago, the charging tripped after just half an hour. After resetting, it tripped again after about 20 minutes. I didn't pay much attention at the time. Today, while charging, it didn't trip the circuit breaker within ten minutes, but it stopped charging and there's no power. I don't know the reason. If anyone has had a similar experience, please advise!
The front windows of the Jetour X70 cannot be opened, and the horn alarms when the car is locked with the remote. When the unlock button on the remote is pressed and held, only the rear windows open, while the front windows do not respond. I had this issue repaired at the 4S shop before, and they said it was related to the fuse. However, the problem has occurred again just two to three months after the repair.
Volvo V60
Volvo V60KWD 10,600Gasoline
