حسن فريد
حسن فريد
Jul 8
Hi everyone, in my second-hand 2014 V60, the manual shift mode can only upshift but not downshift. Is there a problem with the transmission? Any advice?
فهد حريري
فهد حريري2024-07-09 09:31
For safety and to protect the transmission, even in manual mode, the transmission doesn't unconditionally follow manual shift up or down commands. It makes decisions based on engine load, RPM, vehicle speed, and other factors. Manual shifting is just a request signal, not a command signal. The transmission should be fine.
Why can the T60 Petrol 2.0T Automatic 4WD only upshift but not downshift in manual mode?
Hi everyone, how's the quality of the H7? Is it worth getting a second-hand one? The value for money seems good, but I'm not sure about its durability.
Is the engine noise of the 2014 Volvo V60 a common issue? [Crying][Crying] Is it just because the car is getting old? Or is there a design problem with this model? [Shocked][Shocked]
Is it still necessary to buy an imported second-hand V60? Models from 2017 or 2018, second-hand prices are around 270,000 to 280,000.
The child lock on the right rear door of the 2014 V60 is not engaged, but the door cannot be opened from the inside, only from the outside. What could be the issue?
My wife bought an 18-year-old used car, and today I drove it for a few dozen kilometers. I have a habit of occasionally resting my hand on the gear shift. When I did that, I noticed an issue. When shifting from second to first gear, I felt a slight "ka-ta" sensation! The sound is very faint, and you probably wouldn't notice it without your hand on the gear shift. Is this indicating a problem?
Does anyone know if a second-hand 2021 V60 still comes with lifetime free maintenance, or is it only available for the first owner?
[Shocked] What's up with this car? Starting in S mode, I floored the pedal, the RPM hit 4000 and it was still in 2nd gear without shifting up automatically. It only shifted to 3rd gear after releasing the throttle for 3 seconds.
I have a 2016 automatic model, and when driving on good roads, I hear a clear "clanging" sound from the right front tire area. Could this indicate a problem with the shock absorber? I just bought this second-hand car, looking for advice.
Volvo V60
Volvo V60TBDGasoline
