وحيد محمد
2022-09-11 21:40
Hey everyone, I recently noticed a rustling noise near the B-pillar on the passenger side when driving over bumpy roads. I've had the car for a year, but this just started happening. It doesn't make noise on regular bumpy roads, only when the car sways side to side. I've tried fastening the seatbelt and applying grease to the buckle, but the noise persists. Has anyone else experienced this? Any suggestions on how to fix it?
عبد العزيز ماجد
عبد العزيز ماجد2024-10-10 17:29
Check if the soft padding on the inside of the B-pillar is loose.
سلمان خلدون
سلمان خلدون2024-08-22 21:21
I've experienced that too, couldn't find the reason.
Hello everyone, I have a 2011 Comfort M5, and I've had it for a year and a half without any issues. Recently, there's been a rattling noise on the front passenger side when driving on regular concrete roads, like the sound of knocking on wood, which is quite annoying. There's no noise on highways or asphalt roads. What could be the reason for this?
Is there a clunking noise from the front left when driving on bumpy roads? Has anyone experienced this issue?
Has anyone experienced the same issue with the 2016 Jeep Renegade? When driving at speeds of 60-80 km/h over manhole covers or bumpy roads, the rear end feels loose (swaying side to side). The car hasn't been in any accidents, the rubber bushings seem fine, and the wheel alignment data is normal.
Can the rubber bushings be replaced? The car makes a lot of noise when driving over bumpy roads.
When driving above 80 km/h, there's a noticeable noise near the passenger side A-pillar. At higher speeds, like 120 km/h, the noise becomes even louder.
Chery Arrizo 3, sometimes there's a noise above the glove box. When driving, it usually stops, but after turning off the engine, closing the car door might cause the noise again. There's also a similar sound inside the passenger side B-pillar seatbelt. I want to take apart the dashboard to see if something is loose inside, but I'm not sure where to start. I've previously removed the bumper to install a loudspeaker and added a central control screen with a rearview camera. But I'm not sure how to start with the area above the glove box.
Does anyone else experience a ticking noise from the B-pillar while driving? That kind of tick-tock sound.
Hi everyone, I have a rattling noise on the roof. It doesn't make a sound on asphalt roads, but on bumpy roads, it keeps rattling. Has anyone experienced noise from the roof and how did you solve it?
Does your SUV make a buzzing noise from the rear passenger side when driving at speeds of 20-30 on bumpy roads? There's no such sound from the driver's side. Without some music, it's really hard to ignore that noise!
Volvo Volvo V60
Volvo V60TBDPetrol
