عبدالرحمن سعد
2024-11-11 08:31
For car owners of models around 2014 and 2015, have you ever used a USB drive to play music in your car? What formats does your system support? I downloaded a lot of songs yesterday, including WAV and FLAC, but none of them could open. It seems like it only supports MP3.
فهد إسحاق
فهد إسحاق2024-11-11 14:19
Most cars from the 2014-2015 era mainly supported MP3 format.
What video format is needed to play videos from a USB on the CS95? 🤯
How do you play USB music in this car?
I bought a music USB online, but my car can't read it. What format should I change it to?
What formats does the 2017 Jeep Renegade support for USB drives and music files?
What formats of USB drives are supported by the 2017 Jeep Renegade?
Do any of you use a USB drive to listen to music? Does the USB drive need to meet certain requirements? Why can't the songs I downloaded on my previous USB drive play? I used a card reader with a memory card, and it worked before, but now it always switches back to the radio interface.
There could be several reasons why the music USB drive isn't responding when plugged into the USB port of your car or other device: 1. **Compatibility Issues**: Some car USB ports or devices may have compatibility issues with certain USB drives or file formats. Ensure the music files are in a supported format like MP3. 2. **File System Format**: Check if the USB drive is formatted in a compatible file system, such as FAT32 or exFAT, which are commonly supported by car audio systems. 3. **USB Port Problem**: The USB port itself might be faulty. Try plugging the USB drive into a different port if available. 4. **USB Drive Issue**: Although it works on your computer, there might be an issue with the USB drive that affects its performance in other devices. Consider testing with another USB drive. 5. **Device Settings**: Check the settings of the device you're plugging the USB into. Some settings might need to be adjusted to read external USB storage. 6. **Power Supply**: Ensure that the device has enough power supply to read the USB drive, especially if it's an older model or if there are multiple devices connected. Try troubleshooting with these suggestions to identify the cause of the problem.
Can the Cetus car play music online, or can it download apps to play music, or is it only possible to use a USB drive?
Is your 2013 Kia Sportage unable to recognize the USB drive and play music?
What formats does the USB interface support? I'm planning to use a USB drive to play lossless music, and I'm not sure if it supports APE format.
Volvo Volvo V60
Volvo V60TBDPetrol
