Where can I set the three options for the V40 active braking system?
Do I need to activate the system again after upgrading to the new system?
How do I set the seat memory for a 2014 Volvo V40?
Is there any modification for the music system of the GA8? Can you recommend a set?
4Hello fellow car enthusiasts, have any of you experienced this issue where you double-click to activate LCC and it shows as available but just doesn't activate? What's going on, is there a setting problem?
5Can Zilong's front radar be set to always be automatically on by default??? I couldn't find where to set it up.
6Hi, where can I find the time settings for the X90? Thanks.
7Regarding the issue where the 360-degree camera system doesn't activate when reversing, but works fine when the turn signal is on, how can this be resolved?
8Where can I activate the active braking on the Cetus 1.5L naturally aspirated, luxury version?
9Where can I enable the active braking on the Seitus 1.5 Prestige?
10I'm planning to buy a Panamera soon. Initially, I was considering a regular Panamera with options totaling around 140. But I recently discovered that the new Active Ride can only be selected on the e-Hybrid, which is about 16 more expensive even if I forgo some options. Can any owners share whether the Active Ride feature is worth the money? Is it cost-effective?
