عبدالله فهد
2023-02-15 08:49
Comments( 6 )
عبدالله أمين
عبدالله أمين2024-04-01 14:32
My car also has the same issue at a speed of 50-55 km/h, when it's in 5th gear. Once I reach 60 km/h and shift to 6th gear, there's no problem.
سلمان دين
سلمان دين2023-10-03 23:51
It might be resonance.
محمد أمين
محمد أمين2023-08-27 22:24
I have the same issue. When I release the accelerator and then gently press it, there's a roaring sound. But if I press harder to accelerate, it disappears.
عبدالرحمن اسماعيل
عبدالرحمن اسماعيل2023-06-12 02:42
Replace the left and right wheel bearings.
عبد العزيز ممدوح
عبد العزيز ممدوح2023-06-02 22:51
I have a 2016 model as well.
محمد ق
محمد ق2023-03-06 00:05
Vibration around 55 is normal. The shifting logic gets stuck here.
When coming to a stop, the idle speed suddenly drops and it feels like the car is about to stall. This occasionally happens when shifting from D to P while stationary. I've replaced the spark plugs, ignition coils, injectors, high-pressure fuel pump, PCV valve, carbon canister solenoid, air flow sensor, and engine mounts. I've also cleaned the intake carbon deposits and combustion chamber carbon deposits. The problem still exists. Can anyone help me figure this out? [crying][crying][crying][crying]
I've got a 2012 Changhe Liana, and it's been having issues with shaking at idle, while driving, and even more when the AC is on. I've already replaced the spark plugs and ignition coils, and cleaned the fuel injectors and throttle body, but the problem persists. The check engine light comes on frequently. Does anyone know what might be causing this issue?
I've upgraded my 2009 Scirocco with the 187b head unit, but the reverse camera doesn't switch the screen when reversing, although the radar works fine. Interestingly, the reverse camera works normally when the car is off, but not when the engine is running. I've already replaced the head unit and the reverse camera, but the issue persists. Any experts out there who can help?
For a 2011 Volkswagen Phaeton with 130,000 kilometers, experiencing issues with the key frequently failing to unlock the doors or the car not detecting the key inside, along with a loud engine noise, here's what you can do: 1. **Key Issues:** - **Battery Check:** Start by checking and replacing the battery in your key fob, as a weak battery can cause these problems. - **Signal Interference:** Ensure there is no electronic interference around you when using the key. Sometimes other devices can disrupt the signal. - **Reprogramming:** If the issue persists, consider having the key reprogrammed by a professional. 2. **Engine Noise:** - **Oil Level and Quality:** Check the engine oil level and quality. Low or dirty oil can increase engine noise. - **Regular Maintenance:** Ensure regular maintenance is performed, including oil changes and tune-ups, to keep the engine running smoothly. - **Inspect Components:** Have a mechanic inspect the engine components like the timing belt, exhaust system, and other parts that might contribute to the noise. Regular maintenance and addressing minor issues promptly can help maintain the car's performance and longevity.
I've got a 2013 Kia Sportage Manual GL 2.0, and the steering wheel shakes when idling. I've cleaned the carbon buildup in the engine cylinders, the injectors, and the idle valve. I also replaced the spark plugs and engine mounts last year. Any experts out there have any advice?
Due to work, I've moved to a rural area and I'm considering buying a four-wheel drive vehicle. My options are the Haval Raptor and Subaru XV. I want to ask friends here, is the trunk of the XV spacious enough? I have a two-month-old baby and often need to carry a stroller. From the photos, the XV's trunk doesn't look very large. Also, there's a common issue with boxer engines consuming oil—does the XV have this problem too?
I've had my car for four and a half years and it's only done 36,000 km. It's a 2019 model with the 4J11 engine. Recently, when I start it cold, the engine struggles a lot. The RPM doesn't go up immediately, and the needle wobbles between 500 and 1000 for a few seconds, making it feel like it's about to stall. Then the RPM suddenly jumps to 2000-3000 before settling back to normal idle after a few seconds. There are no warning lights, and once it's running, everything seems normal. I've cleaned the carbon buildup and throttle, and checked the intake for leaks, but the issue persists. I'm not sure what to check next. What should I look into?
I've been driving a Suzuki SX4 for over ten years, and now the fuel consumption is higher than before. When I press the accelerator, the RPM goes up, but the speed doesn't increase. I've changed the transmission oil, cleared the engine carbon deposits, and worked on the throttle and fuel injectors, but the RPM is still high while acceleration is slow. Are there any fellow car owners who have experienced similar issues?
Volvo Volvo V40
Volvo V40AED 104,895Petrol
