مدرسي حسين
2024-05-01 07:55
What could cause the engine temperature to suddenly rise while in AC mode during a traffic jam in summer?
نايف زاهر
نايف زاهر2024-08-02 14:43
If the fan is broken, the temperature might rise after parking for a while, showing that it's too high. Replacing the fan should fix the issue.
خالد حميد
خالد حميد2024-06-17 17:27
Park the car and turn on the air conditioner to check if the fan is spinning. If it's not, the fan controller might be faulty.
فهد إبراهيم
فهد إبراهيم2024-06-17 11:11
I recently had the same issue. Have you solved it? I'm afraid to turn on the air conditioning.
What could cause the steering wheel to shake during sudden acceleration? Today, when I suddenly accelerated, the steering wheel shook a lot, and I'm not sure what's going on.
What could be the issue with a 2019 Volkswagen Multivan when the steering suddenly fails and becomes heavy during water fording?
19w km, the vehicle suddenly stalls while driving. What could be the issue?
Is it normal for the idle speed of a 2015 Volkswagen Touran to rise to 900 RPM when the outside temperature is below 0 degrees while the engine is warm?
Why does the transmission overheat during frequent stop-and-go traffic on the highway? After overheating, it causes severe jerking and gear shifting issues.
Have any of you experienced a situation where the engine shakes violently when you release the brakes while waiting at a traffic light? What could be causing this?
Does anyone else experience this issue with the Hongqi H7 1.8T? In the summer, when stuck in traffic, turning on the air conditioning for a few minutes causes the engine to show high temperature.
When I start my 2021 Outlander, there's a popping sound in the engine bay during cold starts, but it goes away once the temperature rises. Has anyone else experienced this?
Is it normal for a 2014 Peugeot 2008 1.6 automatic to have the engine temperature rise very slowly, taking over ten minutes to reach 70 degrees? Could it be that the engine oil is too thick?
Volvo Volvo V40
Volvo V40AED 104,895Petrol
