محمد عبدله
2023-11-08 11:14
The front clip of the electric seat adjustment panel is cracked. Do I need to replace the entire assembly?
علي هشام
علي هشام2023-11-11 22:28
Jack Ma's family has spare parts.
How do I adjust the seat height? I've tried moving it up and down, but nothing happens!
The air conditioning internal circulation of the 2016 Hongqi H7 with the chrysanthemum logo is broken. How can it be repaired? Is it that one of the shafts of the air conditioning flap is broken? Do I have to replace the entire air conditioning assembly?
How to repair a damaged chrome strip on the front grille, or should I replace the entire assembly?
Will it affect the air conditioning if the navigation clip breaks and falls into the air vent? Do I need to take it out?
How do you secure the clip under the rear seat of the HS7? It's always coming loose.
I've heard that the vacuum pump on the Jeep is leaking oil. I've already replaced two gaskets, but it's still leaking. I've been told that I might need to replace the entire assembly. Is that true? Can fellow car enthusiasts share their experiences?
Hey experts, the headlight cover on my Sharan has turned yellow and has lots of small cracks. Can it be repaired, or do I need to replace the cover? Is there any place where I can buy the parts? Thanks.
How do you remove the rear seat cushion of a Taurus? I've managed to release the two front clips, but I'm not sure where the hooks are in the back where it meets the backrest. If any fellow car enthusiasts know, please let me know. Thanks!
How do you adjust the height of the 1.5Pro seat? Please advise.
Volvo Volvo V40
Volvo V40AED 104,895Petrol
