عبدالله غازي
2023-10-29 19:48
The 2014 Zhiya's Blind Spot Detection (BIUS) system showed a fault warning in July this year, but today the fault disappeared and the feature is working again. What could be the reason?
علي هشام
علي هشام2023-10-30 07:27
As long as it works, don't worry. [I want to be alone]
What could be the reason for the Scirocco 2.0 engine warning light to turn off and then come back on again?
Why does the transmission often show a fault code and then disappear on its own shortly after?
Why does the car show a transmission fault warning during a cold start, but it goes away after waiting and restarting?
The instantaneous fuel consumption display has disappeared. How can I get it to show up again?
The 2014 model with a 3.5L engine shows the engine warning light and exhaust system fault light at 100,000 km. The sensors have been replaced, but after a while, the lights come on again. Does anyone know what the reason might be? Generally, the lights only come on when driving at high speeds. Could it be related to the Evans waterless coolant that was changed a few years ago at the 4S shop?
Engine shows fault code, acceleration is weak, what could be the reason?
My car is 3 years old and sometimes it shows a right front indicator fault, but then the warning disappears. I've had it checked at the shop, but they couldn't find the cause. Has anyone else experienced a similar issue?
I have a 2016 Haval H2. Have any of you experienced a brake light fault warning when pressing the brake pedal for a long time, but the warning disappears once you restart and press the brake again?
Guys, I have a 2017 1.6 Zhixing. Last month, while driving, it showed a message to shift to P gear for repair, but it disappeared after a while. This morning, it reported a transmission fault, but after starting the car, it was gone again. What's going on?
Volvo Volvo V40
Volvo V40AED 104,895Petrol
