عمر إسماعيل
2023-11-12 20:37
I have a 2018 V40, and when I start it, the steering wheel and the center console panel shake a lot, especially when I turn on the air conditioning. It's only run about 50,000 kilometers. It takes quite a while for the shaking to reduce. What could be the problem? Has anyone else experienced this?
خالد حميد
خالد حميد2024-01-21 21:45
I replaced the parts for the engine and transmission. The original ones cost a thousand, but they were out of stock. So, I went with aftermarket ones for just two hundred. The issue was resolved immediately (I can accept the slight vibration). You can refer to the post I shared.
خالد حميد
خالد حميد2023-11-28 17:57
The same issue with the engine mount pads aging, there are three in total. Replacing them with original ones outside might cost two to three thousand, or even more. It's better not to go for branded ones. (Replacing just one doesn't seem to work, still shakes. I replaced one and it was useless.)
Hey folks, the cigarette lighter below the center console in my Sportage has power, but when I plug in the car charger, there's no response. The charger is good. What's the issue?
I'm looking for advice from everyone. I want to install a reversing camera on my Mazda 2 and replace the original center console. I'm not sure if the reversing camera center console screens available online are reliable. Do you have any good recommendations?
My 2011 VW Touran shakes a lot when refueling. Any advice?
What does it mean when the V40 shows an "Engine Performance Reduced" message? My fuel consumption has already increased from 9.6 to 10.4 liters. It's really consuming more fuel.
My 2019 Model 95, the USB port next to the cigarette lighter on the center console isn't working. It doesn't charge my phone, and when I plug in a USB drive, there's no response. What's going on?
Does anyone know if the center console screen frame panel of the 2016 model is the same as the 2012 model? I only found the panel for the 2012 model, the one with the air vents.
When the air conditioning is on and blowing cold, the car shakes a lot, especially when stopped at a red light. It's uncomfortable. Do any of you have this issue with your car?
My 2015 manual classic model is shaking a lot when I drive it, and the sound is like it's gasping for air. The power also seems to be lacking. What's going on?
Do you have any abnormal noises coming from the center console of your car? When in Drive (D) and holding the brake, there's a "dang dang dang" sound from the driver's center console. There aren't any issues in other gears.
Volvo Volvo V40
Volvo V40AED 104,895Petrol
