محمد عبد الغفار
Apr 8
I bought a 2017 V40 and recently the engine sounds like a tractor when running. Does anyone know what might be going on? The repair shop said it might be a cylinder scoring issue, but they're not sure.
I recently bought a 2008 S40 with 130,000 kilometers on it. It's running well so far. Any advice on what to watch out for?
The oil light came on while driving the 2012 XV at high speed. I went to the repair shop, and they said it's burning oil. What should I do?
My GAC GS7 has only run 55,000 kilometers, and the turbocharger fan is already broken. The repair shop said it might just be a one-time issue! Have you encountered anything like this?
4I recently found out about this car and really like it, but the dealership in my area doesn't have it anymore. They said it's been discontinued and replaced by the Haval Jolion. I'm not sure if it's really no longer available.
5Help needed, the suspension of my V40 makes squeaky noises when getting in and out or going over speed bumps. I called for advice and they said it might be due to aging bushings. Has anyone else encountered this issue?
6Can a 2009 Peugeot 307 hatchback automatic with 150,000 km go on the highway? I asked the repair shop, and they said it's okay for short distances, but not for long trips.
7I bought a second-hand Kia Sportage that's 10 years old. When going over bumps or speed bumps, the front chassis makes a creaking noise. I asked a repair shop, and they said it's likely the stabilizer bar bushings have aged. Replacing the two front stabilizer bar bushings would cost over 200, but they also mentioned that changing them might not necessarily solve the problem. Do you think it's necessary to replace them?
8I bought a 2017 V40 and recently the engine sounds like a tractor when running. Does anyone know what might be going on? The repair shop said it might be a cylinder scoring issue, but they're not sure.
9The daytime running lights on the 2020 model can't be turned off unless the engine is off. Has anyone gone to a repair shop for modification?
10Does anyone with a V40 have a source for chassis bushings? I want to buy them myself and then find a repair shop to replace them.
