فهد بهاء الدين
2023-11-08 07:50
How to use the V40's automatic parking feature? I've never used it before. Can it park in any type of parking space, or does it have to be a standard marked space? I'm a bit confused.
Today, the maintenance technician suggested switching to Shell's Yellow Bottle motor oil, mentioning that Castrol's oil with cleaning features might cause more oil leaks. Has anyone used lower-quality oil before? Is it usable?
Does it have the automatic parking and auto-exit from parking space feature? Otherwise, with parking spaces being so narrow these days, the automatic door opening feature is significantly less effective.
How do you all use the V40's connected car features?
Is the GV70's all-wheel drive truly full-time, and what is the front-rear power distribution ratio? I've seen some owners say it's not full-time AWD, mentioning that some modes require manual adjustment to four-wheel drive or allow switching to two-wheel drive. I'm a bit confused. Could someone explain the situation with this AWD system and how to use it?
The auto parking feature is really bad. Despite having a parking space, it just can't recognize it. What's the point of buying the top model? Everyone says to support domestic products, but silently supporting them only to be let down! Are you still there?
Hey car enthusiasts, have you noticed this? When you're reversing into a parking spot, the car looks straight, but on the 360 camera, it appears skewed. Before, when I parked using the 360 camera, the image showed the car was straight, but once I got out, the front was actually tilted to the right. And when it seemed straight from the outside, the image showed it was slanted.
Hey fellow car enthusiasts, do you use fuel additives for your 3008? Which brand is good? I've never used them before.
Volvo Volvo V40
Volvo V40AED 104,895Petrol
